Borland C++Builder CLX mode
julien MONTROZIER
Post by julien MONTROZIER » Thu Jan 29, 2004 10:11 am
Hy,
I am using TChart in VCL mode (both C++ Builder 4.0 & 6.0) for many month without any problem, but I need to use it in CLX mode in order to build Linux & Windows compactible applications (Builder 6.0 and Kylix 3).
My problem is that I am not able to use TChart in CLX mode with C++Buider.
That's why I have few questions :
- Does the CLX mode is provided with BCB 6.0 by TChart ?
- If not do you plan to provide a Windows CLX version of TChart ?
- Is there any other solution for us to use the same source code, in CLX mode, in order to build Linux&Windows compactible applications ?
Julien
email : j.montrozier@diginext.fr
Post by Pep » Fri Jan 30, 2004 10:25 am
Hi Julien,
Yes, but the TeeChart Pro with "source code" is required to compile/install the CLX packages.
If you have the TeeChart Pro version with "source code" you should be able to use the VCL or CLX packages.
julien MONTROZIER
Post by julien MONTROZIER » Mon Feb 02, 2004 9:11 am
Hi Josep
Thank you for your answers.
I have the TeeChart Pro "source code" in v.5.
I still have 2 questions :
Is there any special conditions in order to compile this version with
BCB 6.0 ?
What conditions should be added to Build new packages in CLX mode ?
Thank you
Julien
Post by Pep » Mon Feb 09, 2004 10:52 pm
Hi Julien,
>BCB 6.0 ?
Yes, the only version that can be compiled with BCB6 is the latest TeeChart Pro v6.01.
Using the lates TeeChart Pro v6.01.
The prefered way to compile clx packages is to use TeeRecompile tool.
Otherwise, you should open BCB6 TC CLX project group and compile/install everything. But before that you should remove VCL packages (in v6. VCL and CLX still cannot be installed at the same time).
