TeeChart has continuous active wheel
Bruce
Post by Bruce » Sun Feb 09, 2025 1:15 am
Good day
I have one TeeChart on a program page which continually shows a circling active wheel when I hover over the chart. None of my other charts do this. This even happens when I am not loading anything into the multiple series in the chart and have them all set to not show.
When I do load data, I find that I cannot use checkboxes on the legend to show/hide series. I have to use the TeeCommander 'spanners' to access the series to show/hide them. With no data loaded, the legend checkboxes work fine. This might be a function of the amount of data loaded but it does not explain the wheel of death.
Can anybody suggest what I should look for to stop this behaviour?
Bruce
Bruce
Re: TeeChart has continuous active wheel
Post by Yeray » Mon Feb 10, 2025 7:01 am
Hello Bruce,
You could share that chart with us to see if the problem is with some chart setting itself. To do so, you can open the editor and export the chart to a tee file.
