Chart.Axes.Left.CalcIncrement Error
Errol
Post by Errol » Mon Nov 20, 2023 1:11 am
As far as I can ascertain, there appears to be an error in Chart.Axes.Left.CalcIncrement, which in certain cases, returns a default value of 20. I have a graph with the following values:
Chart.Axes.Left.Maximum = 74;
Chart.Axes.Left.Minimum = 67;
In this case, the value of Chart.Axes.Left.CalcIncrement always returns 20.
If I swap the axes around, so that I have:
Chart.Axes.Bottom.Maximum = 74;
Chart.Axes.Bottom.Minimum = 67;
Then Chart.Axes.Bottom.CalcIncrement = 2, as expected.
If I change the units of the data to Maximum = 7400 and Minimum = 6700, I get an increment of 40, as expected.
I would be pleased if you could look into this.
Errol
Errol
Re: Chart.Axes.Left.CalcIncrement Error
Post by Errol » Mon Nov 20, 2023 3:30 am
With a bit more research, I found that the Left Axis was not set to Automatic scaling. When I set this, the problem went away. This was a very old setting and I assumed that manual setting of the axis scaling would override the CalcIncrement procedure. So the problem is solved.
Errol
Post by Yeray » Mon Nov 20, 2023 7:25 am
Hello Errol,
Directly setting Minimum and Maximum properties doesn't set Automatic, AutomaticMinimum or AutomaticMaximum properties. That's why we use to recommend calling SetMinMax(min, max) instead.
