I want to connect to a TDataset but my TdbChart it's display a single record !
Posted: Wed Oct 18, 2023 12:35 pm
by 16565015
I would like to dynamically create a serie to connect to a dataset :
query = select myfield,count(myfield) from XXX group by 1
The code is very simple :
procedure TForm26.Button1Click(Sender: TObject);
  DBChart1.AddSeries(TPieSeries);
  DBChart1.Series[0].DataSource := Q_TABLEFX;
  DBChart1.Series[0].YValues.ValueSource := 'SERIE1';
  DBChart1.Series[0].XLabelsSource := 'GROUPE1';
In an empty project it's work fine. It's display my (multiple record) dataset.
But in my 7 millions of line of code program with the same code my TDBChart display a Single record like this :
and result :
But I want = If I edit (in runtime) my TDBChart to connect to a dataset it's work :
I have tried uses order without change.
Why my TDBChart display it datasource as "Single record" and not as a (multi-record) dataset ?
In other words of to force a dataset or a single record dataset ?
PS : I use Teechart Pro 2023.38.230607 VCL with Delphi 11.3
Re: I want to connect to a TDataset but my TdbChart it's display a single record !
Posted: Wed Oct 18, 2023 1:14 pm
by 16565015
Ok I have understand my mistake.
It's if you connect DBChart1.Series[0].DataSource to a TDatasource component (connected to a Tdataset) !
Strangely in this case it display a "single record" ?!
