How to set pattern for specific donut slice ?
Posted: Fri May 19, 2023 11:01 am
by 16592320
I want to set pattern for specific slice in Donut chart. Is its possible ?
I found UsePatterns property but if set they draw all slices with pattern. But I need specific ones.
So, how to select pattern type, foreground and background colors for specific slise ? Maybe using some event ?
Result should looks like this (made by hand):
Thanks for help !
Re: How to set pattern for specific donut slice ?
Posted: Mon May 29, 2023 12:41 pm
You can do something similar to the explained here:
type TDonutSeriesAccess=class(TDonutSeries);
  Chart1.AddSeries(TDonutSeries).FillSampleValues(5);
  Chart1.OnAfterDraw:=PatternInDonutSliceAfterDraw;
procedure TForm1.PatternInDonutSliceAfterDraw(Sender: TObject);
var donut: TDonutSeriesAccess;
  if (Chart1.SeriesCount>0) and (Chart1[0] is TDonutSeries) then
    donut:=TDonutSeriesAccess(Chart1[0]);
    if pie.Count>1 then
      Chart1.Canvas.Brush.Color:=donut.GetValueColor(1);
      Chart1.Canvas.Brush.Style:=bsFDiagonal;
      donut.DrawPie(1);
Posted: Fri Jun 02, 2023 3:43 pm
by 16592320
Thank you very mush ! I will try !
Posted: Fri Jun 02, 2023 4:30 pm
by 16592320
Its working perfect ! Thank you very much !
