Paul Holden
Post
by Paul Holden » Tue Sep 06, 2022 5:49 pm
I have 2 applications which contain contour series built in code as follows:
var aContourSeries := Chart.AddSeries(tContourSeries) as tContourSeries;
In one application the chart editor "Series" tab has 5 sub-tabs including "Format" and "Grid 3D" in the other application these tabs are missing. Without the Format tab, the user can't reset the contour levels. Any Idea why? The code in both applications looks very similar. See the screenshots below - I note that the version with the extra tabs has a "contour Icon" next to the series name and the other doesn't.
- 2022-09-06 18_35_10-MPPERER Chart Viewer.png (13.63 KiB) Viewed 4395 times
- 2022-09-06 18_33_26-Editing ICE_Chart.png (16.39 KiB) Viewed 4395 times
- Site Admin
Post
by Yeray » Mon Sep 12, 2022 10:17 am
Some tabs are split in different units. You can add the TeeContourEdit
to add the "levels" tab.
However, note the editor is designed to help the developers to build and test their applications, not to be accessed by the final users, so we don't recommend giving access to it.
Paul Holden
Post
by Paul Holden » Mon Sep 19, 2022 2:36 pm
Thanks. Adding TeeContourEdit to the form unit hosting the editor worked fine. I have no idea why the other app showed the contour level tab as that form also did not use TeeContourEdit.
- Site Admin
Post
by Yeray » Tue Sep 20, 2022 7:16 am
Paul Holden wrote: ↑Mon Sep 19, 2022 2:36 pm
Probably that's because at some point in the dependency tree (a unit that references another unit,...), the TeeContourEdit unit is referenced.
Paul Holden
Post
by Paul Holden » Wed Sep 21, 2022 9:12 pm
I think it was a reference to VCLTee.TeeChartBook that exposed the dependency. All a bit random - you might want to think about tidying it up at some point.
- Site Admin
Post
by Yeray » Thu Sep 22, 2022 6:25 am
Hello Paul,
The TChartBook
component has a ShowToolBar
property to show a TTeeCommander
with the TChart
This is the reason why TChartBook
class references TeeComma
unit.
TeeComma
references TeeEditPro
because the commander has an "Editor" button, and TeeEditPro
references TeeContourEdit
and all the series editors.
