Map Series and Zoom
Peeryog
Map Series and Zoom
Post by Peeryog » Mon Jun 06, 2022 10:17 pm
Just getting used to the map series and I hope there is a simple answer,
The zoom and scroll function work great, until I add some code to the OnSeriesClick event. Then that code takes precedence and the zoom function fails to start. This would be on a map , say, and the user is clicking on a state or province and in this case it is desired that clicking anywhere in the polygon that represents the state will perform the OnSeriesClick event.
Is this the behaviour I should expect to see?
Best Regards
Peter
Re: Map Series and Zoom
Post by Yeray » Wed Jun 15, 2022 1:24 pm
Hello Peter,
Indeed, the event is capturing the action and not propagating the event.
If you want to change this behaviour, you can set CancelMouse property to False:
procedure TForm1.Chart1ClickSeries(Sender: TCustomChart; Series: TChartSeries;
  ValueIndex: Integer; Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
  Sender.CancelMouse:=False;
