Statistics ChartTool
Zach A
Post by Zach A » Fri Dec 03, 2021 6:38 pm
I am running into the following problem
a) I have created a new chart tool
b) I activate the charttool in code
c) I assigned a series to it
d) I have created a Tstring variable to hold results
when running the code I am getting an "access violation" error. See code below
var
  sLines : TStrings;
  MyPoints: Array [0 .. 10] of TPointSeries;
      //code to format chart
      chartTool3.Active := true;
      chartTool3.Series := MyPoints[iseries];
     //code to populate  MyPoints[iseries]
    chartTool3.Statistics(sLines); // access violation
Any help would be appreciated
Re: Statistics ChartTool
Post by Yeray » Tue Dec 07, 2021 10:14 am
Give it a try at the example bellow, which seems to work fine for me here. Just drop a TChart and a TMemo into the form at design time.
uses Series, TeeSeriesStats;
var Series1: TLineSeries;
    SeriesStats: TSeriesStatsTool;
  Chart1.View3D:=False;
  Chart1.Legend.Hide;
  Chart1.Color:=clWhite;
  Series1:=TLineSeries(Chart1.AddSeries(TLineSeries));
  Series1.FillSampleValues;
  SeriesStats:=TSeriesStatsTool.Create(self);
  with SeriesStats do
    Series:=Series1;
  Chart1.Tools.Add(SeriesStats);
  SeriesStats.Statistics(Memo1.Lines);
Zach A
Post by Zach A » Tue Dec 07, 2021 5:06 pm
That works. Thanks a lot.
