Text Offset in Chart
niggle
Post by niggle » Tue May 05, 2020 8:21 pm
Has anyone else had the problem with ALL the text on the chart being offset?
I have attached an image to show the problem as it is exported to a metafile, this is where the problem lies, exporting as a bmp file works ok
Re: Text Offset in Chart
Post by Yeray » Wed May 06, 2020 6:12 am
I've just tested it in a simple project and it seems to work fine for me here.
niggle
Post by niggle » Wed May 06, 2020 6:53 am
Hi and thanks for your reply,
I have managed to use the export as BMP option to a memory stream and loaded the image into my PDF from the memory stream and everything is ok and in the right place, it looks to only be a problem with export to metadata. so no need for any follow up for me thanks.
Post by Yeray » Wed May 06, 2020 7:49 am
I'm glad to hear you found a way to make it work as you wish.
Thanks for sharing!
