Chart OnClickSeries not working as expected
ChristianZiegelt
Post by ChristianZiegelt » Thu Mar 29, 2018 9:41 am
Hi all,
I'm currently trying to use the event OnClickSeries() from TChart for a TPointSeries.
Unfortunately, the click event is not always sent.
Marks are enabled in my series. If I click on the mark text or within the marks background, the event is not fired.
Is this the desired behaviour ?
What can I do, to always get the click event if I click on a series item ?
And what is the effect of "ClickTolerance" being "0" or "30"....
Best regards
Christian
Re: Chart OnClickSeries not working as expected
Post by Yeray » Tue Apr 03, 2018 6:39 am
You could use the Clicked function at the OnClick event to see if the Marks have been clicked. Ie:
procedure TForm1.Chart1Click(Sender: TObject);
var ValueIndex: Integer;
    MousePos:   TPoint;
  MousePos:=Chart1.GetCursorPos;
  ValueIndex:=Series1.Marks.Clicked(MousePos.X, MousePos.Y);
  if ValueIndex>-1 then
     ShowMessage('Mark clicked: ' + IntToStr(ValueIndex));
procedure TForm1.Chart1ClickSeries(Sender: TCustomChart; Series: TChartSeries;
  ValueIndex: Integer; Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
  ShowMessage('Point Clicked: ' + IntToStr(ValueIndex));
