Memory leek using GDI instead of GDI+
Whookie
Post by Whookie » Wed Oct 30, 2013 11:55 am
How to trigger the error:
1. Make a new VCL application
2. Drop a TChart component on the main form
3. Edit the TChart: Edit Chart->Chart->3D->render and select GDI instead of GDI+
4. Run the application and close it
using any debug-memory manager of your choice will show you the leek...
As far as I could trace the error it happens in:
procedure TCustomTeePanel.CreateDefaultCanvas;
var t   : Integer;
    tmp,
    tmpClass : TCanvas3DClass;
  tmpClass:=TTeeCanvas3D;
  if IDefaultCanvas<>'' then
     for t:=0 to TeeRenderClasses.Count-1 do
       tmp:={$IFNDEF D18}TCanvas3DClass{$ENDIF}(TeeRenderClasses[t]);
       if tmp.ClassName=IDefaultCanvas then
         tmpClass:=tmp;
         break;
  if (not Assigned(InternalCanvas)) or (tmpClass<>InternalCanvas.ClassType) then
    InternalCanvas:=tmpClass.Create;
    InternalCanvas.ReferenceCanvas:=FDelphiCanvas;
Maybe the only thing to do, is to Free the InternalCanvas:
    if Assigned(InternalCanvas) then
       InternalCanvas.Free;
but I could'nt try it, because the recompile tool seems to override all changes?!
/Edit: Using Delphi XE4 - TeeChart Pro v2013.08.130521 32bit VCL
David Berneda
Re: Memory leek using GDI instead of GDI+
Post by David Berneda » Wed Oct 30, 2013 2:30 pm
This problem is already fixed (InternalCanvas.Free), and will be included in next update.
btw: If you apply the changes at "...\TeeChart Sources\VCL" folder, changes are lost because TeeRecompile tool recreates this folder.
The "original" source unit that can be modified are one level up, at "..\TeeChart Sources" folder.
