Changing Series Color on DBChart (Pie)
Bone
Post by Bone » Sun Aug 01, 2004 9:44 pm
I am using a Pie DBChart. I have selected the two fields in my defined datasource. I want to change the color of the slices, but cannot figure out how to do so. Appreciated in advance.
Marjan
Post by Marjan » Mon Aug 02, 2004 7:46 am
Hi.
You want to change the color of individual slices *after* you've connected it to the color field in database ? This can be done by accessing individual point color. The following code should do the trick:
pie1.ValueColor[2] := clWhite; // 3rd slice color = white
Marjan Slatinek,
Bone
Post by Bone » Tue Aug 03, 2004 2:19 pm
What do you mean "You want to change the color of individual slices *after* you've connected it to the color field in database ?"
Post by Pep » Wed Aug 04, 2004 9:02 am
Hi Bone,
he means that if you want to change the color of individual slices after you've set or asigned a DataSource you must use the code he show you.
