we just upgraded to ver. 2022.36. We have a problem if the axis is scaled in logarithmic and auto mode. It looks like the axis is not scaled to the max value of the graph but to the next higher full decimal number (eg. 1000 or 10000 or 100000 ...)
In 2022.36 all was ok.
We use Delphi 11.1
Willi
logarithmic axis are scaled wrong in release 2022.36
Re: logarithmic axis are scaled wrong in release 2022.36
Thanks!
Sorry, I guess you meant an older version. Could you please correct it so we can compare the changes?
Thanks!
I have seen this as well, logarithmic scaling has changed from 2022.35 to 2022.36. See the attached images.
- Version 2022.36
- Plot 2022_36.png (36.75 KiB) Viewed 6810 times
- Version 2022.35
- Plot 2022_35.png (44.79 KiB) Viewed 6810 times
Hello
In 2022.35 all was ok![Smile :)](./images/smilies/icon_smile.gif)
Hello Willi,
I could reproduce the problem so I've added it to the public tracker (#2564) and also fixed it for the next release.
Hello Yeray,
thank you very much. But is there a workaround because logarithmic scaling is very important for us?
Willi
Willi
Hello Willi,
If you own the sources, you can open the TeEngine.pas unit and substitute the
TChartAxis.LogYPosValue
function for this:
Function TChartAxis.LogYPosValue(Const Value:TChartValue):Integer;
if IRangeLog=0 then result:=ICenterPos
if Value<=0 then
if not FInverted then result:=IEndPos
else result:=IStartPos
if IRadiusAxis then
Begin
if FInverted then result:=Round((ILogMax-ln(Value))*(IAxisLogSizeRange/2))
else result:=Round((ln(Value)-ILogMin)*(IAxisLogSizeRange/2));
result:=ICenterPos-result;
end
Begin
if FInverted then result:=Round((ILogMax-ln(Value))*(IAxisLogSizeRange))
else result:=Round((ln(Value)-ILogMin)*(IAxisLogSizeRange));
result:=IEndPos-result;
