How to draw an elliptic cylinder?
The axis of an elliptic cylinder is a 3D curve, and its cross section at any position is an ellipse. The 3D curve and a series of cross-section ellipses are known. That is to say, we know the 3D coordinates of the curve and ellipses at any position. I have no idea to draw the elliptic cylinder. Would you like to give me an example? Thanks a lot.
- Fig.jpg (28.55 KiB) Viewed 13438 times
Re: How to draw an elliptic cylinder?
I'm afraid there's no series or tool implemented in TeeChart doing this for you, but once you have the data, it should be possible to use a TSurfaceSeries or a TPoint3DSeries to draw it.
It is great and useful.it should be possible to use a TSurfaceSeries or a TPoint3DSeries to draw it.
If it is required to draw a semitransparent surface, how to set Brush’s transparency? Or, is there any other way?
Transparency is applied with Blending:
uses TeCanvas;
var tmpBlend : TTeeBlend;
const transp=80;
//Prepare Pen and Brush
if transp>0 then
tmpBlend:=Chart1.Canvas.BeginBlending(TeeZeroRect,transp);
//Draw polygon
if transp>0 then
Chart1.Canvas.EndBlending(tmpBlend);
It works fine.
How to make such a Series visible or not as required? i.e. use a CheckBox to make it visible or not.
That depends on how are you drawing the polygons. If you are drawing them at a series' OnGetPointerStyle event as in the example I linked above, disabling the series should be enough to stop calling that event and thus your custom drawing code.
