Good morning
I use DBChart to access data from a database and/or a memory table, using XValues, YValues and DataSource in TSeries. Now I wish to add a series with the data either in an array or from calculations. Is there a straightforward way to do this, or do I have to populate a memory table with the data points?
Thank you for your attention
Errol
Using DBChart with text data
Re: Using DBChart with text data
Hello Errol,
Yes, you could use code similar to this:
You could send x and y arrays to the method:
ie.
var vals : array of double;
i : Integer;
SetLength(vals, 8);
for i := 0 to 7 do
vals[i] := Random(10);
Series1.AddArray(vals);
ie.
Series1.AddArray(xVals,yVals);
Hi Marc
Thanks for the solution to my problem. However, I am trying to plot a closed polygon, and I can only plot values in an increasing-X direction. How can I plot the data in array index order.
Thanks and regards
Errol
Thanks and regards
Errol
Hello Errol,
It sounds like the ValueList Order may be what you need here.
Before you add the data, set:
Series1.XValues.Order := loNone;
Series1.YValues.Order := loNone;
Thanks Marc
That did the trick. I had set the Orders, but after I had loaded the data.
Best regards
Errol
Best regards
Errol
