onPaint event high cpu usage [resolved]
toroloco
Post by toroloco » Fri Dec 13, 2019 2:28 am
Hello, I have a client application that needs to have cell-specific text formatting (e.g., bold, font colour, background). I am using the OnPaint event, but notice that the event is continuously firing and taking up high cpu usage. I tried both settings for DoubleBuffered and that did not resolve the issue.
Please advise any workarounds. Thanks!
I am using the latest TeeGrid 2019.
In the test code below, the test label starts counting continuously and does not stop. I am not moving the mouse.
Here is the onPaint code I am using:
// declare the following in the form class:
//		MyData : TStringsData;
//		iCount: Longint;
procedure TForm1.FormShow(Sender: TObject);
	MyData:= TStringsData.Create(3, 10); // 3 columns, 10 rows
	grid.Data:= MyData;
	iCount := 0;
	grid.Columns[0].OnPaint := OnPaintColumn;
	grid.Columns[1].OnPaint := OnPaintColumn;
	grid.Columns[2].OnPaint := OnPaintColumn;
	mydata.Cells[0,0] := 'hello';
	mydata.Cells[1,0] := 'world';
	mydata.Cells[2,0] := '0';
	mydata.Cells[0,1] := 'special';
	mydata.Cells[1,1] := 'line';
	mydata.Cells[2,1] := '37.45';
procedure TForm1.onPaintColumn(const Sender:TColumn; var AData:TRenderData; var DefaultPaint:Boolean);
var
	formatSave: TTextFormat;
	if aDAta.Row = 1 then
		with (Sender.Render as TTextRender) do
			formatSave := grid.Cells.Format;
			defaultPaint := false;
			format.Font := grid.Cells.Format.Font;
			format.Font.Style := [fsBold];
			adata.Painter.SetFont(format.Font);
			Paint(AData);
			format.Font.Style := [];
	end
	else begin
		defaultPaint := true;
	Inc(iCount);
	lblStatus.Caption := timetostr(now()) + intToStr(iCount);
toroloco
Re: onPaint event high cpu usage
Post by toroloco » Fri Dec 13, 2019 3:28 pm
Never mind. The key concept here is to instantiate the special text format, not make a reference. Here is the solution:
	MyData:= TStringsData.Create(3, 5); // 3 columns, 5 rows
	grid.Data:= MyData;
	formatBold := TTextFormat.Create(nil);
	formatBold.Font.Style := [fsBold];
	formatOriginal := grid.Cells.Format;
< if line = ... >
			// background color
			Format.Brush.Visible:=True;
			Format.Brush.Color:=clGreen;
			// bold
			adata.Painter.SetFont(formatBold.Font);
			// font color
			adata.Painter.SetFontColor(clYellow);
			Paint(AData);
			// undo bold and font color
			adata.Painter.SetFont(formatOriginal.font);
