OnClickSeries is not triggered for 3D charts
I'm having troubles with OnClickSeries of TDBChart v2022.36, for FMX in C++Builder. It is not triggered when the chart is 3D.
Is it a bug or is still a functionallity not available?
My project uses a TDBChart with six Bar series and two Area series. It seems that when I added the Area series then the OnClickSeries event starting failing, but now I can't make it work at all.
Is there an alternative way to do it works with 3D charts?
Best regards,
Patricio Cerda
Best regards,
Patricio Cerda
Re: OnClickSeries is not triggered for 3D charts
Hello Patricio,
A simple example seems to be working fine for me but that may depend on the 3D settings in your chart.
Hello Yeray,
Sorry by the delay, I was complicated with other matters.
I have prepared a snipped C++ Builder project where you could see the problem with 3D charts, but unfortunately I can't attache it because their size is 2.7 Mb and is rejected. I want to attach a screenshot of 0,8 Mb but is also rejected.
How can I send to you the project and image?
Best regards,
Patricio Cerda
Best regards,
Patricio Cerda
Hello Patricio,
have you removed all the compiled files before to zip the project to send? This might help to reduce the size.
Best regards
Best regards
Pep Jorge
http://support.steema.com
Hello Pep,
Yes, but the project is FMX and two units are forms (fMain.fmx and fGraficosFlujoCaja.fmx) and have 3,9 Mbyte each one.
This is a very reduce snipped project that have 2.7 Mbyte in compressed format (RAR) derived from the original that is much bigger with 438 Mbyte.
Best regards,
Patricio Cerda
Best regards,
Patricio Cerda
Hello Patricio,
could you upload to any host or place where I can download throught it ?
Pep Jorge
Sure, here is the link with the project and an image.
https://drive.google.com/drive/folders/ ... sp=sharing
Best regards,
Patricio Cerda
Best regards,
Patricio Cerda
Hello Patricio,
I've checked and all seems to work fine here. Please, review that the "hover" is not activated because it can affiect it.
You can also add this code to check.
Best regards,
procedure TForm2.FormCreate(Sender: TObject);
Series1.FillSampleValues();
Series2.FillSampleValues();
chart1.Hover.Visible := False;
procedure TForm2.Series1Click(Sender: TChartSeries; ValueIndex: Integer;
Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
showmessage(inttostr(valueindex));
chart1.CancelMouse := True;
Best regards,
Pep Jorge
Unfortunately it does not work for me.
I added the following code for each series:
DBChart_FlujoCajaFlujoCaja->Series[0]->Selected->Hover->Visible = false;
But can't find CancelMouse property. Do you have documentation for C++?
Best regards,
Patricio Cerda
Best regards,
Patricio Cerda
Hello Patricio,
for C++ should be :
Does it work for you?
for C++ should be :
DBChart_FlujoCajaFlujoCaja->setCancelMouse(true);
Pep Jorge
No, it does not compile in C++ Builder:
This is the error message:
[bcc64 Error] fGraficosFlujoCaja.cpp(324): no member named 'setCancelMouse' in 'Fmxtee::Dbchart::TDBChart'
I did search on a few related .hpp files but couln't find this method.
Just to be clear: I want a solution or workaround to make it work, so I'll appreciate any other suggestion.
Best regards,
Patricio Cerda
Best regards,
Patricio Cerda
Hello Patricio,
Sorry for the delay here.
I can't test your project because there are dependencies I don't have here.
Since the database has probably nothing to do with the problem you are observing, you could export the chart to a tee file and send it to us so we can try to import it here.
By the way,
By the way,
doesn't work for me either but CancelMouse=true;
does.Best Regards,
Hello Yeray,
Sorry too for the delay.
Yes, it does compile and runs but seems not solve the issue:
CancelMouse = true;
I tried to export the DBChart with the following code and obtained the attached .tee file. I hope it is what you asked for, because I couldn't implement the suggested code to export a Chart as on this link: https://www.steema.com/support/viewtopic.php?t=16550
DBChart_FlujoCajaFlujoCaja->SaveToMetafile("C:\\Apps\\teeFile.tee");
Check the .tee file and comment me what you find.
Best regards,
Patricio Cerda
CancelMouse = true;
Best regards,
Patricio Cerda
- teeFile.rar
- (27.14 KiB) Downloaded 494 times
That file attached is a .png with a wrong extension.
To export a chart to a .tee file, you should include the "FMXTee.Store.hpp" in the .h:
And run something like this when the chart is drawn (ie with a button):
#include <FMXTee.Store.hpp>
void __fastcall TForm1::Button1Click(TObject *Sender)
SaveChartToFile(Chart1, "C:\\tmp\\teeFile.tee", true, true);
Ok, now I did generated the correct .tee file.
Thanks Yeray.
I will be waiting for your comments.
Best regards,
Patricio Cerda
Thanks Yeray.
Best regards,
Patricio Cerda
- teeFile.rar
- (1.07 KiB) Downloaded 485 times
