Scrolling/Panning in iOS
Posted: Fri Jun 27, 2014 8:14 pm
by 17568804
Hi all,
I am just doing my first tests with TeeChart in Appmethod 1.14 on the iOS platform. I have the TeeChart source code in my project group and everything compiles just fine.
My idea is to use TGanttSeries to represent an electronic program guide (tv guide) visually - my first tests are quite conclusive but panning/scrolling doesn't quite work correctly.
This is how I configured my TChart:
 fChart.LeftAxis.Automatic := false;
  fChart.LeftAxis.Minimum := -0.5;
  fChart.LeftAxis.Maximum := 5;
  fChart.BottomAxis.Automatic := false;
  fChart.BottomAxis.Minimum := 0;
  fChart.BottomAxis.Maximum := 50;
  fChart.AllowZoom := false;
  fChart.Panning.Active := True;
  fChart.AllowPanning := TPanningMode.pmBoth;
Panning works only once when the app is started and doesn't follow the finger but has an offset. A second attempt doesn't work anymore and the app needs to be restarted for the panning to work again.
Any ideas?
I am using the latest TeeChart 2014 source code for FireMonkey.
Thanks a lot!
CJ
Re: Scrolling/Panning in iOS
Posted: Fri Jun 27, 2014 8:20 pm
by 17568804
For completeness - here is the entire test file with my first steps (only mockup code):
https://github.com/darktab/simpleEPG/bl ... GFrame.pas
CJ
Posted: Tue Jul 01, 2014 10:42 am
by Pep
in order to make work the pan/scroll over the chart you have to add the following line of code to your code :
 fChart.ScrollMouseButton := TMouseButton.mbLeft;
Posted: Tue Jul 01, 2014 5:56 pm
by 17568804
Thanks!
This is the solution!
One more question though - what's the recommended way to pan/scroll only inside some arbitrary bounds?
Christian
Posted: Tue Jul 01, 2014 8:56 pm
by 17568804
A way I succeeded in doing so, was implementing the onScroll event with this:
if (fChart.BottomAxis.Minimum < 0) then
    fChart.BottomAxis.Maximum := fChart.BottomAxis.Minimum + 50;
  if (fChart.BottomAxis.Maximum > 70) then
    fChart.BottomAxis.Minimum := 20;
    fChart.BottomAxis.Maximum := 70;
which then blocks scrolling on the bottom axis to a boundary between 0 and 70.
Posted: Wed Jul 02, 2014 10:49 am
cjacoby78 wrote:A way I succeeded in doing so, was implementing the onScroll event with this:
Yes, onScroll event is the way to limit the scroll to a known area.
Posted: Wed Jul 02, 2014 11:35 am
by 17568804
Thanks a lot!
