Are Teechart (including series) threadsafe?
Posted: Sun Jun 01, 2014 11:17 am
by 16566869
Is there any samples for that?
I want to handle teechart with sth. time spending in the boost::thread ..
Re: Are Teechart (including series) threadsafe?
Posted: Mon Jun 02, 2014 8:08 am
No, TeeChart isn't thread safe.
See this reply:
http://www.teechart.net/support/viewtop ... afe#p62498
Also note the "Multi-CPU Parallel Threads" section in the What's New page.
Posted: Tue Jun 03, 2014 2:39 am
by 16566869
Thank you.
So you mean that it is OK if handling Teechart(including series) in one thread(not only the main thread)
as following.
Chart1->AutoPaint = false;
//Do sth. with Teechart and Series
Chart1->AutoPaint = true;
Chart1->Repaint();
Posted: Tue Jun 03, 2014 3:05 am
by 16566869
But when I add data two TFastLineseries, some AV error like attachment arose.
Posted: Tue Jun 03, 2014 3:07 am
by 16566869
If I mask "Series->Add ", it seems OK..
What is d2d1.dll, is it a part of Teechart?
Posted: Tue Jun 03, 2014 4:11 am
by 16566869
Further information, I replaced Add() with AddArray(), the error didn't arise...
Posted: Tue Jun 03, 2014 10:34 am
elmec wrote:So you mean that it is OK if handling Teechart(including series) in one thread(not only the main thread)
as following.
Chart1->Repaint();
Yes, this should be the way.
elmec wrote:But when I add data two TFastLineseries, some AV error like attachment arose.
We'd need a simple example project we can run as-is to reproduce the problem here to further investigate this.
elmec wrote:If I mask "Series->Add ", it seems OK..
No, it isn't.
elmec wrote:Further information, I replaced Add() with AddArray(), the error didn't arise...
Both Add() and AddArray() call the same AddXY function. The only difference is that AddArray() calls BeginUpdate() before adding the values and EndUpdate() when finished.
So you could try with:
Series->BeginUpdate;
Series->Add(yourValue);
Series->EndUpdate;
