Problems with TBubbleSeries
CUS
Post by CUS » Wed Oct 12, 2011 2:41 pm
I have (finally) gotten the pre-release of TeeChart installed, and I am having some problems with the Bubble Series.
1) I cannot get the Data in the series cleared. Is there a way to do that?
2) I will need a label along the Left Axis rotated so that it read down-to-up. Is there a way to do that?
3) The Color boxes seem to work intermittently. Is there a way to get the same text Delphi uses in the drop-downs in the Style editor? That would simplify things greatly to get the colors matching up.
4) Can the bubbles in the bubble series be clipped so that they stay inside the back panel?
5) Is there a way to get the bounding rectangle of the back panel?
6) Is there a way to force the back panel (or the first quadrant) to always be square?
7) Titles seem to always revert back to being drawn in blue, rather then my preferred black, bold.
At first, it seemed to be working OK, but then after I shut down XE2, then re-loaded I got this error:
1) "Error reading Series3.Pointer.HorizSize: Pointer size must be greater than zero. Ignore and continue?..."
2) then...VertZise, too
3) I now get a run-time error "Pointer size must be greater than zero." and am dead in the water.
Thank you for your time.
Re: Problems with TBubbleSeries
Post by Yeray » Fri Oct 14, 2011 11:10 am
CUS wrote:1) I cannot get the Data in the series cleared. Is there a way to do that?
At runtime you can clear the date in a series by (assuming you want to clear the first series in the chart):
Chart1[0].Clear;
At designtime you can clear the data in a series with the "Clear" button in the "Series\Data Source" tab, with "Random" selected in the combobox.
CUS wrote:2) I will need a label along the Left Axis rotated so that it read down-to-up. Is there a way to do that?
To rotate the labels in an axis you can use:
Chart1.Axes.Left.LabelsAngle:=90;
CUS wrote:3) The Color boxes seem to work intermittently. Is there a way to get the same text Delphi uses in the drop-downs in the Style editor? That would simplify things greatly to get the colors matching up.
I've added the possibility to change the colorpicker to the old one, that is more practical (TV52015786).
CUS wrote:4) Can the bubbles in the bubble series be clipped so that they stay inside the back panel?
You are right. I see the series aren't clipped. I've added it to the wish list to be implemented in future releases (TV52015787).
CUS wrote:5) Is there a way to get the bounding rectangle of the back panel?
I think you are looking for this, isn't it?
Chart1.ChartRect
CUS wrote:6) Is there a way to force the back panel (or the first quadrant) to always be square?
I'm not sure to understand what do you mean. Do you mean the left and bottom axes scales or the ChartRect?
Please, take a look at the example at "All features\Welcome !\Axes\Isometric Axis" in the features demo program included with the installation.
CUS wrote:7) Titles seem to always revert back to being drawn in blue, rather then my preferred black, bold.
The following code seems to work fine for me here. Doesn't it for you?
Chart1.Title.Font.Color:=claBlack;
If you still have problems with it, please try to arrange a simple example project we can run as-is to reproduce the problem here.
CUS wrote:At first, it seemed to be working OK, but then after I shut down XE2, then re-loaded I got this error:
It would be helpful if you could arrange a simple example project we can run as-is to reproduce the problem here too.
CUS
Post by CUS » Mon Oct 17, 2011 8:23 pm
To where shall I send this?
Post by Narcís » Tue Oct 18, 2011 7:41 am
Hi CUS,
You can attach it here or post it at the upload page.
CUS
Post by CUS » Tue Oct 18, 2011 4:29 pm
On the Upload Page as ToSteema.zip
CUS
Post by CUS » Tue Oct 18, 2011 9:19 pm
Oh yeah. How to compile under xCode. I got a 'Could not find unit FMX_Tee_Engine" error
CUS
Post by CUS » Wed Oct 19, 2011 4:44 pm
OK, I got it starting to compile in xCode.I had to change some ReadStr calls to ReadString in Canvas.
I am now getting this error:
FMXTee_Canvas.pas(16029,1) Fatal: Internal error 200602041
Fatal: Compilation aborted
Post by Yeray » Thu Oct 20, 2011 8:46 am
Hello CUS,
CUS wrote:On the Upload Page as ToSteema.zip
I've seen you have some "empty" values in your first series (they have "Radius=0"). If I remove them, the HorizSize&VertSize are recalculated according to the values in your series and the axes min&max, and the error doesn't appear any more. The steps I followed: Go to the editor tab "Series/Series1 (the first one)/Data Source". Select Random and apply with 1 number of sample values. Then, change the combobox to manual and set the values you had in the first point "Text=0", "Y=11" and "Radius=2.5". Close the editor.
CUS wrote:OK, I got it starting to compile in xCode.I had to change some ReadStr calls to ReadString in Canvas.
Could you please send us a simple example project we can run to reproduce this as well?
Thank you in advance.
CUS
Post by CUS » Thu Oct 27, 2011 9:54 pm
Try this.
** Project removed by Yeray. There were some TeeChart units included in it.
Post by Yeray » Mon Oct 31, 2011 10:50 am
Hello CUS,
I found no problems compiling and running your project here with XE2 and the PreRelease version v2011.04. Could you please check the paths in your IDE?
PS: Excuse me for editing your last message.
CUS
Post by CUS » Mon Oct 31, 2011 2:36 pm
It compiled in XE2, but not in xCode.
CUS
Post by CUS » Wed Nov 02, 2011 6:45 pm
FMXTee_Canvas.pas(8976,5) Note: Local variable "Center" is assigned but never used
FMXTee_Canvas.pas(8977,5) Note: Local variable "Radius" is assigned but never used
FMXTee_Canvas.pas(10798,7) Note: Local variable "P0" is assigned but never used
FMXTee_Canvas.pas(2638,16) Hint: Local type "PPoints" is not used
FMXTee_Canvas.pas(13452,3) Note: Local variable "AlphaBlendChecked" not used
FMXTee_Canvas.pas(13453,3) Note: Local variable "CanUseWinAlphaBlend" not used
FMXTee_Canvas.pas(14311,15) Hint: Local type "PColorRGB" is not used
FMXTee_Canvas.pas(14316,14) Hint: Local type "PRGBList" is not used
FMXTee_Canvas.pas(15185,5) Note: Private field "TFilerAccess.FRootAncestor" is never used
That line seems to be the start of the initialization section.
Post by Yeray » Wed Nov 09, 2011 9:00 am
Hello CUS,
Excuse us for the delay here. We are investigating this but our experience with XCode is limited.
We haven't forgotten this.
Note this isn't the final release and we expect to revise this for the stable release.
dcore
Post by dcore » Mon Nov 21, 2011 11:12 pm
Still a problem! Now with slightly different linenumber...
FMXTee_Canvas.pas(16044,1) Fatal: Internal error 200602041
Post by Yeray » Tue Nov 22, 2011 4:18 pm
Hello dcore,
Are you using the final v2011.04 release? Are you experiencing the same problem CUS exposed with a different project? If it's simple, could you please send it to us?
