Add rectangle fails
TeeChart for PHP
rustydiver
Add rectangle fails
Post by rustydiver » Fri May 03, 2013 7:16 pm
The code below from this thread -- http://www.teechart.net/support/viewtop ... 11&t=12762 does not work.
    $chart1 = new TChart(800,600);
    //$chart1->getChart()->getAspect()->setView3D(false);  //it seems to break the custom drawing brush
    //****  RENDER RENDER RENDER  ****//
    $chart1->render("chart1.png");
    $g=$chart1->getGraphics3D();
    $g->getBrush()->setVisible(true);
    $g->getPen()->setColor(Color::BLACK());
    $g->getBrush()->SetColor(Color::BLUE());
    $g->Rectangle(new Rectangle(10,10,100,100));
    $g->getBrush()->SetColor(Color::WHITE());
    $g->Rectangle(new Rectangle(170,170,270,270));
    $g->getBrush()->SetColor(Color::RED());
    $g->ellipse(400,400,500,550);
    imagepng($g->img, "chart1.png");
    $rand=rand();
    print '<img src="chart1.png?rand='.$rand.'">';
It produces a blank chart preceded by.. (similar to the save image to file errors)
Warning: imagecolorallocatealpha(): 247 is not a valid Image resource in C:\xampp\htdocs\------------------\sources\GraphicsGD.php on line 2158
Warning: imagefilledrectangle(): 247 is not a valid Image resource in C:\xampp\htdocs\----------------\sources\GraphicsGD.php on line 2179
Warning: imagecolorallocatealpha(): 247 is not a valid Image resource in C:\xampp\htdocs\----------------\sources\GraphicsGD.php on line 2891
Warning: imagesetstyle(): 247 is not a valid Image resource in C:\xampp\htdocs\-----------------\sources\GraphicsGD.php on line 2205
Warning: imagesetthickness(): 247 is not a valid Image resource in C:\xampp\htdocs\-----------------\sources\GraphicsGD.php on line 2208
Warning: imagerectangle(): 247 is not a valid Image resource in C:\xampp\htdocs\-------------------\sources\GraphicsGD.php on line 2210
Warning: imagecolorallocatealpha(): 247 is not a valid Image resource in C:\xampp\----------------\sources\GraphicsGD.php on line 2158
Warning: imagefilledrectangle(): 247 is not a valid Image resource in C:\xampp\htdocs\------------------\sources\GraphicsGD.php on line 2179
Warning: imagecolorallocatealpha(): 247 is not a valid Image resource in C:\xampp\htdocs\------------------\sources\GraphicsGD.php on line 2891
Warning: imagesetthickness(): 247 is not a valid Image resource in C:\xampp\htdocs\------------------\sources\GraphicsGD.php on line 2208
Warning: imagerectangle(): 247 is not a valid Image resource in C:\xampp\htdocs\-----------------\sources\GraphicsGD.php on line 2210
Warning: imagecolorallocate(): 247 is not a valid Image resource in C:\xampp\htdocs\------------------\sources\GraphicsGD.php on line 1210
Warning: imagefilledellipse(): 247 is not a valid Image resource in C:\xampp\htdocs\---------------\sources\GraphicsGD.php on line 1219
Warning: imagesetstyle(): 247 is not a valid Image resource in C:\xampp\htdocs\-----------------\sources\GraphicsGD.php on line 1225
Warning: imagesetthickness(): 247 is not a valid Image resource in C:\xampp\htdocs\-------------\sources\GraphicsGD.php on line 1228
Warning: imageellipse(): 247 is not a valid Image resource in C:\xampp\htdocs\----------------\sources\GraphicsGD.php on line 1231
Warning: imageellipse(): 247 is not a valid Image resource in C:\xampp\htdocs\-------------\sources\GraphicsGD.php on line 1231
Warning: imagepng(): 247 is not a valid Image resource in C:\xampp\htdocs\----------------\test_chart.php on line 26
Re: Add rectangle fails
Post by Yeray » Wed May 08, 2013 1:50 pm
I could reproduce the problem so I've added it to the wish list to be further investigated (TF90016569).
rustydiver
Post by rustydiver » Wed May 08, 2013 2:02 pm
OK... you notice that the errors are too similar to the save image to file error to be coincidence, right? "247 is not a valid..."
Post by Pep » Wed May 15, 2013 7:21 pm
yes, this is the same problem as in the other post. For the moment the best way I can think of if to remove the "imagedestroy($g->img); " from the render() method of TChart.php file. Then you should be able to make it work (also a good example could be the EventsDemo.php of the Features example project (at Miscellaneous folder).
In the case you want to create several charts you can always call the following line after all has been displayed :
imagedestroy($chart->getChart()->getGraphics3d()->img);
