getImageMode() never called!
Posted: Sat Mar 23, 2013 12:31 pm
So how would you get a tiled/centered image on the panel/wall?
Steema Software - Customer Support Forums
http://support.steema.com/
It's a public function you can use to check the value of the imageMode property. Internally, it is directly used the imageMode property in thegetImageMode() never called!
chartEvent
Here you have an example of how to use the CENTER mode:znakeeye wrote:So how would you get a tiled/centered image on the panel/wall?
private void initializeChart() {
Bar bar1 = new Bar(tChart1.getChart());
bar1.fillSampleValues();
checkExternalStorage();
Image im = null;
if (mExternalStorageAvailable) {
if (mExternalStorageWriteable) {
final File ExtPath = new File(Environment.getExternalStorageDirectory().getAbsolutePath() + File.separator + "Download");
ExtPath.mkdirs();
String path = ExtPath.getAbsolutePath() + File.separator + "flower.jpg";
im = new Image(path);
ChartImage chIm = new ChartImage(tChart1.getChart());
chIm.setImage(im);
chIm.setImageMode(ImageMode.TILE);
//chIm.setImageMode(ImageMode.CENTER);
private boolean mExternalStorageAvailable = false;
private boolean mExternalStorageWriteable = false;
private void checkExternalStorage() {
final String state = Environment.getExternalStorageState();
if (Environment.MEDIA_MOUNTED.equals(state) || Environment.MEDIA_SHARED.equals(state)) {
// We can read and write the media
mExternalStorageAvailable = mExternalStorageWriteable = true;
} else if (Environment.MEDIA_MOUNTED_READ_ONLY.equals(state)) {
// We can only read the media
mExternalStorageAvailable = true;
} else {
// Something else is wrong. It may be one of many other states, but
// all we need
// to know is we can neither read nor write
mExternalStorageAvailable = mExternalStorageWriteable = false;
