![Image](http://www.s-iberia.com/images/tmp/chartlinux.png)
Small bug in Linux
- Site Admin
- Contact:
Re: Small bug in Linux
Hi Dmitry,
Does this only happen in Linux machines? Have you been able to consistently reproduce this in different computers? With which TeeChart, Java Runtime Environment, development environment and Linux versions occurs?
Linux linux19 2.6.25.20-0.5-pae #1 SMP 2009-08-14 01:48:11 +0200 i686 i686 i386 GNU/Linux
OpenSuse 11.0
java version "1.6.0_15"
Java(TM) SE Runtime Environment (build 1.6.0_15-b03)
Java HotSpot(TM) Client VM (build 14.1-b02, mixed mode)
version TeeChart?
TeeChart for Java Build 2.0.0.801 (SWT)
OpenSuse 11.0
version TeeChart?
- Site Admin
- Contact:
Hi Dmitry,
Thanks for the info. I forgot to ask you how axes titles text is being added.
And I forgot to say you that strange symbol appear in other title ( chart.getChart().getTitle().setText("Disk pool usage");)
I set title so
chart.getAxes().getLeft().getTitle().setText("% Utilization");
Just do it
I set title so
Just do it
Your code doesn't provoke the error when tested on Windows. We'll run the test on Linux too. In the meantime, your image shows Chart headers 'BACKUP - ALL' and 'ARCHIVE - ALL'. Those titles don't display the problem; how are those titles set that differs from the problem you find via the code 'chart.getChart().getTitle().setText("Disk pool usage");' ? Are you using a different code line?
With thanks.
With thanks.
Strange symbols appear again but on Windows System
![Image](http://www.s-iberia.com/images/tmp/strange.png)
![Image](http://www.s-iberia.com/images/tmp/strange2.png)
SWT version is version 3.550
- Site Admin
- Contact:
Hi Dmitry,
We can not reproduce this in Windows and Swing project with Netbeans in Linux. We are also testing SWT in Eclipse and Linux.
BTW: Do you use any specific code for setting those strings?
Attention.
I changed swt library to new 3.550 and strange symbols appeared at once.
We've installed swt 3.550 and repeated tests. We're not seeing the error here. We may have missed something, are you able to send us a small sample project that reproduces the error? The error appears as if an extra character is adding itself to the line at some stage, a new-line or carriage return for example.
With thanks.
With thanks.
I started your example from source. Strange symbol is too.
![Image](http://www.s-iberia.com/images/tmp/strange3.png)
swt 3.5
swt 3.5
If you run the TeeChart examples from the compiled swt example folder, do you see the same error?
I used your source code and compiled with new swt.
If run compiled swt example(TeeChart.SWT.Features.jar) result is normal without strange symbols
