Windows Vista compatibility
TTL
Post by TTL » Fri Nov 11, 2005 5:47 pm
Is TeeChart 7.0.0.5 compatible with the upcoming Windows Vista? Are there any issues I should be aware of?
Thanks you,
Alex
Post by Narcís » Wed Nov 23, 2005 10:52 am
Hi Alex,
I'm afraid it doesn't work properly. We need to do some further tests. I'll get back to you when we have some news.
Post by Narcís » Wed Dec 14, 2005 10:45 am
Hello TTL,
We have done some tests with latest Windows Vista and TeeChart Pro ActiveX builds available. We found that it generally works but there seems to be a problem with surface type series. We will be doing further investigation on that.
Post by Narcís » Wed Dec 14, 2005 12:55 pm
Hello TTL,
I tested again using v7.0.0.6 installer and surface series worked fine. However, it seems that the installer can't do everything it should as creating the start menu program group or database connections for the database charts demos.
Ronald
Post by Ronald » Fri Oct 13, 2006 6:31 am
Hi there,
What's the current status?
Is Vista fully supported now?
Also for 64-bit systems ?
Post by Pep » Wed Oct 18, 2006 11:22 am
Hi Ronald,
for the moment Vista still not supported, we'll prepare a version compatible when the latest Vista version will be out.
Yes, TeeChart can work with 64 bit system but using the 32 bit "mode" option.
