Fading popup menu leaves garbage
TTL
Post by TTL » Wed Aug 17, 2005 8:32 pm
I am using Visual Studio C++ 6 and TeeChart Pro v7 ActiveX 7.0.0.5.
I have a 3D surface that I am rotating. There's also a popup menu with an option to restore defaults. The popup menu is brought up by right-clicking the chart. When selecting to restore defaults, the chart restores to those values, but region of popup menu item that was selected contains garbage.
I tried to Repaint() the chart, invalidate window, and resize control in the COMMAND message handler of the menu item in question, without success. Seems like the fading out effect terminates after the Invalidate(), and Invalidate() has no effect on the chart.
Is there a workaround for this situation?
I have a sample project that I could upload as an example. How do I do that?
Post by Narcís » Thu Aug 18, 2005 6:59 am
Hi TTL,
Yes please, post your examples at [url]news://www.steema.net/steema.public.attachments[/url] newsgroup.
TTL
Post by TTL » Tue Aug 23, 2005 2:47 pm
Hi Narcis,
I uploaded the project to the newsgroup a couple of days ago. Were you able to reproduce behavior that I've described?
Alex
Post by Narcís » Tue Aug 23, 2005 3:16 pm
Hi Alex,
Thanks for the example project.
No, I'm not able to reproduce it here even though I commented the Sleep(500) line. Are there any special instructions I should proceed with to reproduce it?
Post by Narcís » Wed Aug 24, 2005 8:53 am
Hi Alex,
A technical department colleague has been able to reproduce the problem. This only occurs using OpenGL and has something to do with mouse repainting. For now we haven't been able to find a workaround. We will let you know when we have some news.
Post by Narcís » Wed Aug 31, 2005 8:38 am
Hi Alex,
We have been able to reproduce that only with NVidia GeForce graphic cards with latest drivers from NVidia. However it wors fine with older drivers (i.e.: version 5.6.7.2 from 24/03/2004). Which graphic cards and drivers are you using on the machines where this problem occurs?
TTL
Post by TTL » Wed Aug 31, 2005 4:38 pm
Hi Narcis,
My video card is an Intel 82865G. Driver version is 6.14.10.4020.
Alex
Post by Narcís » Fri Sep 02, 2005 7:12 am
Hi TTL,
Could you please try using a diferent version of your graphic card drivers even it's an older version? Could you also test that application in any other machine with a diferent graphic card?
As I told you we only reproduced that with a specific version of NVidia drivers.
