Functions and How to Stop using them ?
hansw
Post by hansw » Sat Dec 27, 2003 2:22 am
I have a moving average function working (thanks Josep) .
Now when the export data is called there are two columns in the data file !
I just want the original and not the moving average data. !
How can I stop exporting the moving average data ?
I suspect it's a call is needed to turn off the moving average function, but the tutorial does not explain how to do that !
Pep
Post by Pep » Mon Dec 29, 2003 8:42 am
Have you set the Series that you want to export using :
    VARIANT TheSeries;
    TheSeries.vt=VT_I2;
    TheSeries.intVal=0;
    m_chart.GetExport().GetAsText().SetSeries(TheSeries);
    m_chart.GetExport().GetAsText().SaveToFile("c:\\mydata.txt");
Josep LLuis Jorge
http://support.steema.com
hansw
OK... but... !
Post by hansw » Mon Dec 29, 2003 4:07 pm
The code sample you gave works fine, however
I'm allowing the user to select the format using
m_Chart1.GetExport().ShowExport();
That still exports the raw data and the moving average data.
How do I force the ShowExport() dialog to only use the data I want it to use ?
Post by Christopher » Mon Dec 29, 2003 4:24 pm
Hi -
You could remove the unwanted data (series) from the chart before calling IExport.ShowExport, e.g. (sorry for the VB code, but the TeeChart objects, properties, methods and events are identical in VC++):
Private Sub Command1_Click()
With TChart1
    .RemoveSeries 1
    .Export.ShowExport
    .AddSeries scLine
    .Series(1).DataSource = "Series0"
    .Series(1).SetFunction (tfMovavg)
    .Series(1).FunctionType.Period = 1
End With
With TChart1
    .Aspect.View3D = False
    .AddSeries scCandle
    .AddSeries scLine
End With
Thank you!
http://groups.google.com
http://codenewsfast.com/
hansw
VB and V++ do not use the same methods...
Post by hansw » Tue Dec 30, 2003 5:25 am
VB code
With TChart1
.RemoveSeries 1
.Export.ShowExport
I think it's something like
m_Chart1.Series(1).RemoveSeries();
Does not compile there is no function RemoveSeries();
I hate VB it sucks...
Marjan
Post by Marjan » Tue Dec 30, 2003 6:33 am
Or you could simply set series/function ParentChart property to null. In effect, doing the same as RemoveSeries.
Marjan Slatinek,
hansw
Would be nice if....
Post by hansw » Tue Dec 30, 2003 11:10 am
Sounds like a real elegant way to do this...
I've tried just about every "hint" in the VC IDE but found nothing that looks like ParentChart...
