Hello! How to express two graph
rush kim
Post by rush kim » Thu Sep 25, 2014 9:16 pm
Hello~ ^^
I could not find a graph that represents the direction of the wind and wind velocity at the same time an example.
How can i fix this coding.. help me..
Chart1.Legend.Visible=true
  Chart1.Header.Text(0)= tag_no
  Chart1.Header.Font.Color=vbBlack
  Chart1.Header.Font.Bold=True
  Chart1.AddSeries(22)
  Chart1.Aspect.View3D=False
  Chart1.Panel.Gradient.Visible=false
  Chart1.Panel.Color=black
  Chart1.Panel.BevelOuter=1
  Chart1.Panel.BevelWidth=2
  Chart1.Axis.Bottom.Labels.Angle=0
if res.bof or res.eof then
j = 1
Do until res.EOF
				setday = res("sday")
				data2 = res("data2")
Chart1.Series(0).Add data2, setday, clTeeColor
res.MoveNext
j = j + 1
loop
end if
Response.BinaryWrite (Chart1.Export.asNative.SaveToStream(True))
Chart2.Legend.Visible=true
  Chart2.Header.Text(0)= tag_no
  Chart2.Header.Font.Color=vbBlack
  Chart2.Header.Font.Bold=True
  Chart2.AddSeries(fastline)
  Chart2.Aspect.View3D=False
  Chart2.Panel.Gradient.Visible=false
  Chart2.Panel.Color=black
  Chart2.Panel.BevelOuter=1
  Chart2.Panel.BevelWidth=2
  Chart2.Axis.Bottom.Labels.Angle=0
if res2.bof or res2.eof then
j = 1
Do until res2.EOF
				setday = res2("sday")
				data = res2("data")
Chart2.Series(0).Add data, setday, clTeeColor
res2.MoveNext
j = j + 1
loop
end if
Response.BinaryWrite (Chart2.Export.asNative.SaveToStream(True))
Re: Hello! How to express two graph
Post by Yeray » Fri Sep 26, 2014 11:05 am
I'm not sure to understand what's wrong in the resulting images you attached. Could you please explain what result would you expect?
rush kim
Post by rush kim » Sat Sep 27, 2014 8:14 pm
Hi~
It's not result image... ^^;;;
it's want results....
and it's only one page source.
above image --- OK
below image ---- do not express
Post by Yeray » Mon Sep 29, 2014 11:22 am
I'm still not sure to understand what exact result would you expect.
I see the first chart seems to draw date times in the horizontal axis of the WindRose series, but I don't know if this is what you'd expect, what are setday and data2, what are they supposed to represent and which one is correctly represented in the image you posted, if any.
And the same for sday and data in the second chart.
Note the XValues in the WindRose represent the angle, and the YValues represent the radius of each point.
So, if you want to add points with angle and value, you should use AddXY. Ie:
  TChart1.AddSeries scWindRose
  TChart1.Series(0).AddXY 15, 50, "", clTeeColor
  TChart1.Series(0).AddXY 30, 70, "", clTeeColor
  TChart1.Series(0).AddXY 45, 30, "", clTeeColor
