TeeChart Pro ActiveX v2013 release Build 2013.0.1.4
Gemma
Post by Gemma » Thu Nov 21, 2013 8:58 am
Greetings,
The latest TeeChart Pro ActiveX v2013 release is available for download now from the Steema web.
TeeChart Pro ActiveX customers with valid subscription may download the version via the customer download page.
Release notes for the build may be viewed at the version info page.
Gemma Gibert
Alberto
Re: TeeChart Pro ActiveX v2013 release Build 2013.0.1.4
Post by Alberto » Sat Feb 22, 2014 5:14 pm
I recently bought the activex teechart because I needed it to be transparent but I can not manage to make it so. :cry:
Does this version solves this?
Can you help me?
Post by Narcís » Mon Feb 24, 2014 8:05 am
Hi Alberto,
Which specific chart element do you need to be transparent?
Alberto
Post by Alberto » Mon Feb 24, 2014 11:49 am
Hello Narcís,
I need line (and fast line) panel (and rest of the graph except axis, numbers, etc. and lines) to be transparent.
Alberto
Post by Narcís » Mon Feb 24, 2014 1:53 pm
Hi Alberto,
In that case you should do something as in the example Yeray posted here. It's a Delphi example but the same applies to TeeChart ActiveX. Bear in mind that TeeChart Pro ActiveX is a COM wrapper of TeeChart Pro VCL. Example sources:
unit UTranspChart;
interface
uses
  Dialogs, ExtCtrls, TeeProcs, TeEngine, Chart, jpeg, TeeSurfa,
  TeeMapSeries, Series, ImaPoint, TeCanvas, TeeGDIPlus;
type
  TForm1 = class(TForm)
    Image1: TImage;
    Chart1: TChart;
    Series1: TFastLineSeries;
    procedure Chart1BeforeDrawChart(Sender: TObject);
  private
    { Private declarations }
    Back : TBitmap;
  public
    { Public declarations }
var
  Form1             : TForm1;
implementation
{$R *.dfm}
  Chart1.Color:=clNone;
  Chart1.Walls.Back.Visible:=False;
  Series1.FillSampleValues;
procedure TForm1.Chart1BeforeDrawChart(Sender: TObject);
  if not Assigned(Back) then
    Back:=TBitmap.Create;
    Back.Width:=Chart1.Width;
    Back.Height:=Chart1.Height;
    Back.Canvas.CopyRect(Chart1.ClientRect,Canvas,Chart1.BoundsRect);
  if Chart1.Color=clNone then
     Chart1.Canvas.Draw(0,0,Back);
end.
Hi Alberto,
unit UTranspChart;
interface
uses
type
    Image1: TImage;
    Chart1: TChart;
  private
    Back : TBitmap;
  public
var
  Form1             : TForm1;
implementation
{$R *.dfm}
end.
Alberto
Post by Alberto » Mon Feb 24, 2014 3:09 pm
Hi Narcís,
Thanks very much for your help.
Nevertheless, I program in VB 2010 and sorry for been so nuisance but can you tell me how to do that in this language.
I can not access to components as easy as in Delphi probably can be done.
Thanks in advance and best Regards
Alberto
Post by Yeray » Wed Feb 26, 2014 11:11 am
Hello Alberto,
I've been trying to translate that Delphi example to VB 2010 but I haven't achieved it.
I'm afraid we haven't found a way to make the container transparent in ActiveX.
Alberto
Post by Alberto » Wed Feb 26, 2014 2:20 pm
Hello Yeray,
I am a bit upset for this, as I bought the activex with the expectation to get these graphics transparent.
I would like to know if I can get the activex source so that I can change it myself.
Alberto
Post by Narcís » Thu Feb 27, 2014 3:20 pm
Hello Alberto,
After some more investigation I found the equivalent VB 2010 project of the Delphi project I pointed you at. It can be downloaded here: http://steema.com/files/public/Transpar ... XChart.zip
The key was finding the exact properties that match the VCL/ActiveX ones and also some type conversions from .NET to ActiveX. One interesting article on the subject is this: http://blogs.msdn.com/b/andreww/archive ... image.aspx
Alberto
Post by Alberto » Thu Feb 27, 2014 3:25 pm
Dear Narcís,
Thanks so much for your answer. I will try it and let you know.
Alberto
