AddNullXY
nefis
AddNullXY
Post by nefis » Wed Dec 10, 2003 11:19 am
how can i add a invisible point to series wich not affect scale of the chart?
I mean when i use something like
TChart1.Series(0).AddNullXY(Now, 0, "")
the chart is rescaled to accomodate the new 0 value. Since the visible values are in range, say, 1000-1200 the chart becomes indecipherable
nefis
Post by Pep » Wed Dec 10, 2003 12:01 pm
You could use the AddNull method :
TChart1.Series(0).AddNull ""
Josep Lluis Jorge
http://support.steema.com
nefis
Post by nefis » Wed Dec 10, 2003 12:26 pm
Pep wrote:You could use the AddNull method :
Josep Lluis Jorge
it's not working. you coud try it by corresponding modification of the "Multiple Axes" project from TeeChart samples
SS
AddNullXY
Post by SS » Wed Dec 10, 2003 4:25 pm
To get around this we did two things.
1) if no non-null points previously in the series, once you have a good first point go back and update the value.
2) if other the previous value was not null then carry that value to the next null.
[Ex. if points 1 to 5 were value = 50 and point 6 is null then the value for point 6 use 50
-OR-
If points 1 to 5 were null and point 6 is value = 50 , go back and update points 1 to 5 to have a null value of 50]
nefis
Re: AddNullXY
Post by nefis » Wed Dec 10, 2003 4:37 pm
9080016 wrote:To get around this we did two things.
thanks, SS, it should work.
but I still hoping that there is a "normal" way to do it
nefis
nefis
Post by nefis » Thu Dec 11, 2003 10:11 am
Pep,
i'm still hoping that there is a "normal" way to do it. Is there?
The problem with the solution offered by SS is that there is a possibility of situation when long sequence of NULL values in a series happens in the very beginning of the series. It spoils output of series with "regular" values showed with the same axis.
nefis
Post by Christopher » Mon Dec 15, 2003 11:55 am
Hi -
Mmm, well, neither AddNull() nor AddNullXY() offer the possibility of adding in a series point whose YValue is not associated with an axis.
OK. In this instance you will simply have to clear the series of all values and add in the Null values' YValue based on the data point YValue, no?
Thank you!
http://groups.google.com
http://codenewsfast.com/
nefis
Post by nefis » Tue Dec 16, 2003 9:08 am
Christopher Ireland wrote: OK. In this instance you will simply have to clear the series of all values and add in the Null values' YValue based on the data point YValue, no?
I could think of ways around the issue. But the most simple solution might be NOT USING NULL POINTS IN MAX/MIN CALCULATIONS. the only problem with the solution is how to separate "regular" values fom Nulls. Well, you could use say minimal or maximal value for double type ( 4.94065645841247E-324 or 1.79769313486231E+308) as value of Null constant
nefis
